Discussion topic: DNS Issues?
This message was authored by LGUser This message was authored by: LGUser
Re: DNS Issues?
@Shamonemofo wrote:
Had problems most of last night with many sites and apps timing out with the message  ERR_NAME_NOT_RESOLVED.
Anyone know what the cause/fix?
One solution is to get a modem/router that's compatible with Sky and you can change the DNS no problem. You'd also be able to hve WIFi 6 and a better WiFi signal.
This message was authored by Mr+Flibbles+86 This message was authored by: Mr+Flibbles+86
Re: DNS Issues?
Posted by a Sky employee
Update – Thanks for chatting to us. We are still waiting to discuss with you about this. If you need our support let us know and we can re-escalate to our chat team. Your chat has been closed now. Thanks
This message was authored by JohnyNic This message was authored by: JohnyNic
Re: DNS Issues?
I've got the same issue, annoyingly a couple of the kids will be playing online and not notice the issue, but we have to reboot the router to so everyone else can continue browsing and doing other Internet work.
I was going to upgrade to Full Fibre but this is going to stop me going with sky.
This message was authored by BRONX+BOMBER This message was authored by: BRONX+BOMBER
DNS problem blocking two web sites from the same server
This morning was on a web site which I am an administrator  two hours later tried to log on and got a message there was a problem with the DNS?? Been onto Sky and they told me to de activate the BROADBAND SHIELD which I have done but the problem is still there?
Re: DNS problem blocking two web sites from the same server
What is the URL so we can try it?
Re: DNS Issues?
Re: DNS Issues?
@BRONX+BOMBER
"DNS_PROBE_FINISHED_NXDOMAIN"
Non existant domain.
Can you set the device up on google dns or cloudflare to rule out/in sky dns issues
Re: DNS Issues?
sorry dont now what you mean? How do I do it? I know nothing about these techincal things..
Re: DNS Issues?
@BRONX+BOMBER
What device and operating system are you using
Re: DNS Issues?
@BRONX+BOMBER
There's something wrong with the nameserver configuration for that domain: multiple DNS providers can't resolve it.  If you don't administer the hosting yourself then you should contact whoever does.
Re: DNS Issues?
PC with windows 10. but tried it on my android mobile and getting the same mroblem
Re: DNS Issues?
@BRONX+BOMBER
It's a nameserver issue, nothing to do with the device that the web browser is running on.
Re: DNS Issues?
Thanks I only administer the postings. I dont know anything about the intricacies of how the web site operateds. My friend who started the web site. does all that Are you saying the problem isnt with SKY it is with the wiganwworld server?
This message was authored by Aeox This message was authored by: Aeox
Re: DNS Issues?
I get the same issue even if i try to open up Youtube or something. Seems to happen every night around midnight and 1am
Re: DNS Issues?
Yes, it's a server-side issue: specifically the nameservers for the hosting provision (ns1, ns2 and ns3 at meganameservers.eu) don't seem to be responding
