Discussion topic: DHCP and DMZ
This message was authored by Ben182 This message was authored by: Ben182
DHCP and DMZ
Hello I need to activate DHCP and DMZ on my router please I'm trying to log in but it's not go on to the settings.
Re: DHCP and DMZ
@Ben182 The DHCP settings are in the web interface at 192.168.0.1 but you will be required to log in to access them the user is always admin the password on every hub except the old flat type is the default password on the hub's label. The flat type has the password is sky by default.
If you understand what you are doing you can edit the DHCP settings and on the black hubs you can turn off the DHCP server. There is a setting for configuring the DMZ on the black hubs it is greyed out on the white hubs as you use the Hub's advanced settings in the My Sky app.
 Not being rude but beware of editing these settings unless you fully understand what you are doing. Forcexample the DMZ allows the device to bypass the firewall so opens thst devicecto external threats which is OK if you know how to mitigate those threats. However if you mess up you can factory reset the hubs quite easily.
