Discussion topic: DDNS with Asus Router
This message was authored by: sinanx
I want to use DDNS for my Home Assistant to be reached from outside, so I bought an Asus RT-AX53U. I have Full Fibre, I removed Sky router and I connected cable from ONT unit directly to Asus Router WAN input. Wifi etc works fine.
When I try to set DDNS from Asus router settings, its says the Router is behind another router and has a private IP, requiring port forwarding from parent router. In this case I assume router sees ONT as parent modem. Is there a way to use DDNS in this setup?
Re: DDNS with Asus Router
I think that's incorrect: while an ONT is indeed a modem, it doesn't do Network Address Translation or have IP functionality (i.e. it's specifically not a 'router')
Avatar for sinanx
Thanks Timmy. BTW with Sky Router, the connection from ONT is goint to a LAN port. I used WAN port of the Asus Router. might this be the problem?
Or is there any other way to set up DDNS with Sky Full Fibre?
@sinanx
The asus has a seperate blue wan port whilst with the skyhub you sacrifice a lan port by plugging into lan port 4
By definition eth #4 is acting as a WAN port when connected an ONT: it has to for the broadband to work.  They've just saved some money in manufacturing by using a standard four port ethernet module.
@sinanx
What WAN IP is your Asus router showing? (Obviously dont post the IP on the forum but is it a public or private one)
I am NOT a Sky Employee
Avatar for sinanx
Thank you all for the answers. I guess it was a transient issue. I reconnected the cables again and now it is working.
