Discussion topic: Copper Switch Off
This message was authored by: heatherdawn
Copper Switch Off
Hi.
I live in Warminster, Wiltshire and I'm still using an old copper phone line connection for my Sky broadband.
These copper lines are of course due to be disconnected at the start of next year but I've heard nothing from Sky to say when I'll get fibre installed.
Time is running out and I will contact Sky but any thoughts from yourselves on here?
 Thanks.
Re: Copper Switch Off
@heatherdawn
Sky will contact you when you are due an upgrade to fibre due to the cooper line being withdrawn so if you are happy then just stay as you are, otherwise have you looked at your account to see if fibre upgrade options are showing for you:
https://www.sky.com/broadband
This message was authored by: Me134
@heatherdawn wrote:
Hi.
 Thanks.
It's the PTSN (public switched telephone network) that's getting turned off next year (maybe), you may be on FTTC (fibre to the cabinet) which still uses the copper pair from the cabinet in the street.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
As @Me134 indicates, that's not correct.  There's considerable confusion on this issue, largely because the target date for the endpoint of the commercial phase of the national Openreach FTTP deployment now coincides with the twice delayed* PSTN (analogue voice service) switch-off, despite these not actually being the same project.
Given that full-fibre will still not be within reach of at least 15% of UK addresses by 'the start of next year' (and is actually connected in far fewer of them) it's clear that discontinuing broadband over copper entirely is still a long way off: many millions of properties would be left without service if it happened now.
*PSTN was originally scheduled to end in December 2025
https://commonslibrary.parliament.uk/research-briefings/cbp-9471/
Avatar for heatherdawn
Thanks for clarifying.
I'm on Sky Broadband Superfast which will be FTTC.
Just to be sure, will my broadband continue to be delivered via copper wire next year and beyond if I don't upgrade to fibre?
Thanks.
In most cases, yes.
In some exchange areas Sky doesn't have the equipment to provide Sky Talk Internet Calls over FTTC, so current customers there need to either move to FTTP if that's available locally or switch to a different ISP.
@TimmyBGood wrote:
In most cases, yes.
If they don't need or use the landline, would Sky be happy for now at least to continue with the FTTC in that scenario?
Not a Sky employee
@Me134
Apparently not.  I suspect Sky administration and billing systems are  inherently linked to the phone number assigned to the circuit.
