Discussion topic: Constant connection problems.
Message posted on 09 Jan 2026 09:28 AM
For about a month, maybe longer, I've been having constant connection problems.
I've tried everything, resetting everything, disconnecting all devices.
For several months, there were no problems, if any, it was sporadic.
Now I lose internet two, sometimes three times an hour. It lasts about a minute, sometimes longer.
It's impossible to work or enjoy entertainment.
I hope someone can help me because I'm close to canceling my contract because I'm waiting for a heart transplant, and a stable connection is very important to me. I live in the city center (Darlington), but my mobile network coverage is terrible.
Thank you for your help.
Message posted on 09 Jan 2026 09:40 AM
Re: Constant connection problems.
@Milecki Start with this link below, what do you see when your connection is lost if anything?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Message posted on 09 Jan 2026 10:09 AM
Thank you for your reply.
I don't remember the exact order,
but I think I'll be able to write soon because I'm expecting another incident.
Thank you again, I'll update the post soon.
Message posted on 09 Jan 2026 10:21 AM
@Milecki If you need then you can also do the check for yourself, here is the link below for that!
Try running the line test here to see if any faults are found:
Message posted on 09 Jan 2026 12:35 PM
The sequence is as follows:
First from the left: red for 3 seconds.
Next is orange and flashes for 8 seconds.
Third is green, fourth is red.
After a minute, the third turns green, and the fourth returns to red after another minute.
Sorry for the confusion.
Message posted on 09 Jan 2026 01:21 PM
P.S. I don't have phone service, only internet.
Message posted on 09 Jan 2026 01:28 PM
What was the results of the tests you ran from the link posted by @JimM1 ?
Message posted on 09 Jan 2026 01:40 PM
Everything is fine, but for now I only checked when the router is working.
I will check the message when there is a problem.
Message posted on 09 Jan 2026 01:42 PM
@Milecki All four lights on that sky Broadband Hub Green across the board, and you do have a phone service, every sky system sold has talk but if you don't have a phone plugged into the back off the sky hub then the free call dialing 150 to sky is just not an option, plus the voice light would require to be Green anyway for a working connection on your landline!
Message posted on 09 Jan 2026 01:43 PM
@Milecki Run the diadnostic service now, that is the whole point off it, and it checks out your line condition!
Message posted on 09 Jan 2026 01:46 PM
Yes, yes. I don't have a phone, yet the light is red when there's a problem and turns green last.
Message posted on 09 Jan 2026 01:48 PM
Right now, all the LEDs are green. The service is fine. I'll have to check when the problem occurs.
Message posted on 09 Jan 2026 01:51 PM
@Milecki It's all your choice, if you have a bad line, then you will be dropping out left/right and centre, the diagnostic is a two pronged test, and a call to sky also get's a line check done! It's all in your hands now nothing else the Forum can do for you!
Message posted on 09 Jan 2026 01:56 PM
I'll try connecting to Sky.
If the problem persists, I'll have to change providers.
I can't be certain of my network connection.
I also require this from my doctors.
Thank you very much for your help.
Message posted on 09 Jan 2026 01:58 PM
Ps: "We’ve tested the broadband connection to your home and everything looks good. But if you think there's an issue, check your WiFi".
