Discussion topic: Constant buffering
Message posted on 05 Apr 2026 11:40 AM
Constant buffering
All of our tv apps - bbc, itv, prime etc have over the past 2 weeks started buffering every 5mins or so. Never had this problem previously. Ran several tests on the sky website but they all say there is no problem with the broadband or wifi. Was hoping this would resolve itself but hasnt. Tried restarting the router, clearing the cache on the apps, plugging ethernet into the tv but nothing seems to work. Any suggestions?
Message posted on 05 Apr 2026 05:48 PM
Re: Constant buffering
@Jugers go into the Netflix app find the Get Help menu and run the network test which will tell you the speed the app is connecting at. You need at least a steady 25Mb/s to watch in UHD. If the speed is Ok buffering could be caused by someone else in your household using lots of bandwidth or from interference from a neighbour's network. If you suspectvthe latter try rebooting your Sky hub as thst will cause it to find the least congested channel.
Message posted on 12 Sep 2026 02:52 PM
Had the same issues with the new white box. Had 2 engineers out couldn't solve it said it was the Sonos's that I had but the black hub worked fine.
Moved to virgin had no issues 2 weeks in also paying 50% less than I was and I was a sky customer for 13 years.
