This discussion topic has been answered Discussion topic: Consistent ping spikes when gaming
Message posted on 30 Jul 2024 11:12 PM
For almost a year now, I have been experiencing consistent ping spikes when gaming on my PC. These ping spikes mainly occur on Roblox, in which my ping spikes every few seconds or minutes. I believe that my PC is not the cause of the problem due to the fact that, even after resetting my PC multiple times in an attempt to resolve the issue, I still encounter these ping spikes. However, I am also not certain of this as the ping spikes started occuring quite recently after I received my PC.
A few months ago, I played games through ethernet (although I am unsure if I can call it ethernet as it was not connected directly to my router) - I had an ethernet cable connected from a Sky Wi-Fi booster in my room to my PC. Despite having an ethernet cable connected to my PC, I still encountered ping spikes which led to me removing the ethernet cable. As of right now, I use Wi-Fi with the Sky Wi-Fi booster behind my PC.
My dad called Sky for support about a month ago, yet I believe that he did not provide enough information about it and just claimed that there was 'something wrong with our Wi-Fi' - in the end they said that there was nothing wrong with our Wi-Fi. It also seems like I am the only one experiencing this issue in my house which led to me believing that it was something to do with QoS as I am the only one who really does gaming. This may be a stupid question due to me not knowing much about Wi-Fi and other topics related to it, but would the possiblity of the problem being QoS be eliminated if I still experienced ping spikes when home alone?
Apologies for the large amount of text, but I am quite desperate to fix this issue as it has a significant impact on me when gaming competitively, so I wanted to provide as much information as I could to try and get a fix. After looking at other posts on here about ping spikes, I have started to think about buying a Powerline Adapter and connecting an ethernet cable from it to my PC, yet I do not know if it would be any different from a Sky Booster and connecting an ethernet from it to my PC. I would greatly appreciate any support.
Message posted on 31 Jul 2024 07:09 AM
@ypbtc noSky router supports QOS - quality of service - which is where gaming data is prioritised you would need to buy a gaming router to get that. While it could be an issue with the hub not being able to pass data smoothly if for example other family mrmbers are streaming video while you are gaming I would suspect your WiFi setup.
Boisters act as relays receiving data from the hub and retransmiting it to your device. A booster can only therefore provide 50% of the bandwidth it gets from the hub so having a booster close to the device is going to reduce speeds (your PC's wifi card will get roughly the same speed from the hub as the booster). The second wifi jump also introduces increased latency and doubles the chances of wifi interference and packet loss. Boosters should be placed no more than halfway between the location of the hub and the device simply removing the booster from where it currently should help.
You are right using an ethernet cable to a WiFi booster is rarely sensible. A far better set up where direct ethernet is impossible is to buy a powerline networking kit (aka Home Plugs) which uses your home's mains wiring to carry the data which reduces latency and packet loss due to interference.
Message posted on 31 Jul 2024 05:00 AM
Re: Consistent ping spikes when gaming
When playing games do you download games in the background on the PC? If so, then that will cause issues with latency (ping). QoS will allow traffic to be prioritised for gaming on a router but Sky's routers don't support QoS, unfortunately.
Message posted on 31 Jul 2024 05:10 AM
No - I always make sure that there are no games in the background open when downloading other games.
Message posted on 31 Jul 2024 07:44 AM
My latency to Australia.
Message posted on 01 Aug 2024 06:00 PM
@Chrisee After reading your response I was considering buying a powerline adapter, but after watching a video on how to set one up, one of the tips include plugging the powerline devices into wall outlets instead of power strips. The problem for me is that there are no avaliable wall outlets for one of the powerline devices (in this case the one that would be near my router) - instead there are only extensions which I believe would result in reduced performance. Do you think that it would still be worth buying one even if it meant using extensions?
Message posted on 01 Aug 2024 06:05 PM
@ypbtc You can buy adapters with pass through mains sockets so retaining the mains out let for devices.
Message posted on 13 Jul 2025 06:14 PM
Apologies for replying almost a year later - but I would like to update my situation in which I have encountered another problem. After your initial reply to my post (which was really helpful so thank you for that), I got rid of the WiFi booster and bought a powerline adapter in which I connected an ethernet cable to it. This resolved my ping spikes, however it also caused my internet speed to fall by a small amount so I just let it be as I did not see it as much as a problem. One of the only problems that was caused by the powerline adapter was that it took quite long for me to load into games such as Roblox after first booting up my pc. Nevertheless, I think the fact that it fixed my ping spikes outweighed the increased loading time so I did not attempt to fix it.
Recently however, as the UK heat is getting worse and my room has become even hotter than before I installed an air cooler inside my room which I use alongside an electric fan which I have been using even before I was using my PC (the socket that it is placed next to is directly next to the powerline adapter). On the page of the powerline adapter that I bought from Amazon, it states that electrical equipment with electric motors such as electric fans and air conditioners generate interference and can even cut off my Powerline speed connection. I did not really notice this when I got my powerline adapter - however after installing the air cooler I have noticed it more signifcantly and frequently through the decrease in my internet speedtest results after unplugging my fan; I get a few ping spikes when I play games such as Roblox (though they are quite rareamd I don't know if it caused by the powerline adapter). Despite this, I don't think they are that much of an issue. Another problem which has occured though is that the connection to my phone seems to have become worse.
My dad recently called Sky and they recommended us to upgrade our router so that we can have additional WiFi boosters installed into our house, however as you said in your reply to my original post connecting an ethernet cable to it is not smart. As a result, I am thinking of a getting rid of the powerline adapter and getting a long, Cat 6, UTP pure copper ethernet cable (recommended by Reddit) which is connected directly from my router downstairs to my PC upstairs (though I'm not sure how I will set it up yet) so that I can still have my fan and air cooler running in my room. I am also considering whether upgrading would actually be beneficial so that I can get a WiFi booster in my room again - despite it previously having a negative impact on my PC it actually helped in relation to the connection to my phone so maybe that could be the case again. For this possible solution though, I have two questions: would installing a WiFi booster in my room affect a direct ethernet connection from my router to my PC? Also, would the ethernet cable be affected by the fan and air cooler in my room - I don't really want to remove them. I would appreciate your feedback in response to my situation and possible solution.
