Discussion topic: Connectivity to non-Sky device
This message was authored by: Chris847
Message posted on 28 Jun 2026 10:38 AM
Failed to connect Arlo device after switching to Sky broadband
Find out more
Message posted on 28 Jun 2026 10:55 AM
Re: Connectivity to non-Sky device
@Chris847 any WiFi capable device can connect to a Sky hub but it can be difficult. I assume you have an Arlo camera which I suspect may only connect to the 2.4GHz band WiFi and has issues with a dualband SSID. If thst applies and you have a white Skybhub find the hub's advanced settings temporarily turn off the 5GHz band connect the camera once connected turn the 5GHz band back on. Hooefully thst should sort it.
