Discussion topic: Connections Issues
This message was authored by: LNS123
Connections Issues
I work from home and have been having frequent issues with connectivity. The last few days specifically have been patchy, losing connection and calls dropping or feeezing.
this is happening where there isn't any major usage of the hub.
Issues are occurring with both the WiFi and the network connection
This message was authored by: Waveman
Re: Connections Issues
Do you have full fibre?
If you have full fibre is your ONT on line correctly? Power light, PON Light should both be on, LAN light should be flickering. A red LOS light indicates a problem.
If this does not reveal anything then you will need to contact Sky to resolve,
https://www.sky.com/help/articles/contacting-sky
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
