Discussion topic: Connection
Message posted on 22 Jul 2026 02:50 PM
Connection
Message posted on 22 Jul 2026 03:57 PM
Re: Connection
Hi @JackieOrvis
When it drops out, do you notice any lights change on your hub? Have you tried the Sky line test to see if it flags any drops?
As for not being able to connect any device in your bedroom, this is likely a WiFi range issue. You can get WiFi extenders from Sky if you have the WiFi Max addon.
Message posted on 22 Jul 2026 04:16 PM
Re: Connection
Hi yes the light changes to red
Not tried what you sergested how do I go about doing that ?
Thank you Jackie 😊
Message posted on 22 Jul 2026 04:23 PM
Re: Connection
Hi @JackieOrvis
Head over to this link https://www.sky.com/servicechecker
Or on the My Sky app go to the broadband area and run a line test.
