Discussion topic: Connection
This message was authored by: Kearney6
Connection
There is an error detected but the app is just sending me in circles from checking WiFi or broadband- both say the connection is fine but I have none. Randomly cut off now without wifi.
Re: Connection
@Kearney6
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
