Discussion topic: Connection
Message posted on 02 Feb 2026 02:29 PM
Connection
I can't connect to my wifi
Message posted on 02 Feb 2026 02:31 PM
Re: Connection
@Sarah613 you would have to give some more details before forum members can help. However as step one check the lights on the Sky hub see https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 02 Feb 2026 02:32 PM
Re: Connection
@Sarah613 Has this just happened for the connection, if so what do you see when looking at the sky Hub!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
