Discussion topic: Connection
Message posted on 10 Jan 2026 02:37 PM
Connection
My internet connection is not working. I have completed all the checks and it says it should all be working fine the lights aren't on and I can't watch any apps.
I have been on hold for over an hour!
This is really annoying and disappointing!
When someone initially answered he kept asking if I want to renew my contract then transferred me to the wrong department and now I've been on hold for 1.15mins so far with no idea of where I am in the queue.
Can anyone help?
Message posted on 10 Jan 2026 02:41 PM
Re: Connection
@Parvendra
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Unfortunately due to the Sky Q issues overnight the lines are likely to be extra busy today.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
