2
This discussion topic has been answered Discussion topic: Connection
This message was authored by: Rachael79
Connection
My WiFi is connected but I keep getting wrong password, when I'm putting exactly the given password into my devices
Re: Connection
@Rachael79
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
Re: Connection
@Rachael79
Avatar for Rachael79
Re: Connection
Thanks for your reply. I was reading capital I as small L. Got it fixed and its all good
