Discussion topic: Connection
This message was authored by: Carl93
Message posted on 29 May 2025 04:58 PM
Connection
I've had an engineer round today to change me over to fibre but cannot get WiFi as saying incorrect password
Find out more
Message posted on 29 May 2025 05:24 PM
Re: Connection
Were you given a new hub by Sky, if so the password to use is the one printed on both it and the card that came with it. Make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
