Discussion topic: Connection
Message posted on 14 Apr 2025 08:36 PM
Connection
The Wi-Fi will only connect to some of gadgets in the house it's not reaching to one room
Message posted on 15 Apr 2025 07:35 AM
Re: Connection
@Sammy34 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
