Discussion topic: Connection to tv
Message posted on 17 Jul 2026 05:10 PM
Connection to tv
My tv is stating the connection is poor and I have tried everything to fix it but since the wifi has been installed it has been slow and I work fro
home so I can not have slow internet
Message posted on 17 Jul 2026 05:14 PM
Re: Connection to tv
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
