Discussion topic: Connection to mini box
This message was authored by: Mininox
Keep getting message can't connect to main sky q box from mini box, this is so frustrating that if not fixed I am cancelling my package, this is more so since I upgraded to better WiFi hub, all other WiFi products work fine it's only my mini boxes
Re: Connection to mini box
@Mininox you need to call Sky if the Sky Q minis are not connecting to the main Q box as they should either send you a Q booster or arrange for an engineer to come. The issue is caused by the fact the new white Sky Max hub does not support the now old Sky Q wifi mesh so cannot connect to the Q minis by WiFi.
@Mininox
And note the key is to emphasise it's a Q television issue, rather than a more general one with WiFi.  Sky charges extra to address the latter.
