Discussion topic: Connection to Epson printer failed
This message was authored by: MumC
Message posted on 07 Oct 2026 06:50 PM
We have an Epson XP- 2205 printer. On trying to set it up with the WiFi it won't connect. Just keeps flashing
Find out more
Message posted on 07 Oct 2026 07:11 PM
Re: Connection to Epson printer failed
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
