Discussion topic: Connection problems
This message was authored by: Diana77
Connection problems
17.30 every day my internet drops out and I never get wifi on my phone even when next to the router.
Re: Connection problems
Hi @Diana77
When the issue occurs do any lights on the hub change?
Do you have anything timed in your home for 17:30 or something thats often used at that time?
I am NOT a Sky Employee
Avatar for Diana77
No lights change. Nothing changes in the house. Today it's faulty earlier. 16.30
Hi @Diana77
Which Sky hub do you have? https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
@Diana77 Two things spring to mind, parental controls but you would need the sky Max for that one, and have a look at the Broadband shield settings on your account!
