Discussion topic: Connection problems
Message posted on 07 Apr 2024 11:15 PM
Connection problems
Hi we've had the new fibre glass internet installed around a month ago. And the last 5 days the connection is really poor. On the app says good connection and passes the tests but every device linked is having dipping issues where it dips on and off. That's tv phones iPads and play stations. We ordered the top mbps at 900 but the highest I've seen it reach is around 4/500 which isn't what we are paying for. Could we get some help please. Many thanks
patrick
Message posted on 08 Apr 2024 10:15 AM
Re: Connection problems
Are the affected devices connected by ethernet cable or WiFi?
Message posted on 08 Apr 2024 11:46 PM
Well this embarrassing thought this was a message to sky directly lol.
but in answer I think it's WiFi?
phone service with sky has dipped in and out today too
Message posted on 09 Apr 2024 07:30 AM
@Southamptonfc the forum isnt a channel to contact Sky themselves it is primarily customer - to- customer support.
Normally full fibre is very reliable however no system is 100% reliable. The lights on your Sky hub are there to tell you what is going on the Internet light and the voice light should always be green if one is amber it indicates an issue outside your home so you need to call Sky to get support.
If all of the LEDs are green then the service to the hub is working and slow devices etc are likely be due to poor connection almost always due to poor WiFi connection.
