Discussion topic: Connection keeps on dropping!
This message was authored by: Rhina
My Internet keeps on dropping! Very annoying, as Im working from home! This has been on-going since Friday!!!
Re: Connection keeps on dropping!
@Rhina
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
