This discussion topic has been answered Discussion topic: Connection keeps dropping
Message posted on 04 Jan 2026 04:46 PM
Message posted on 04 Jan 2026 04:51 PM
@JBA2369
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@JBA2369
Message posted on 04 Jan 2026 05:00 PM
Re: Connection keeps dropping
Thank you. It's been established we need an engineer after following one of your links. And running a diagnostic test.
