Discussion topic: Connection keeps dropping
This message was authored by: PaulineV1977
We have full speed fibre broadband but over the last three to four weeks have had a lot of issues with connectivity- Reset router many many times and still struggle to have it stay online for more than 5 minutes at a time.
these are the stats for our router - Would be great if someone could help diagnose the issue
Router Statistics
System Up Time: 00:02:46
Port
Status
TxPkts
RxPkts
Collision Pkts
Tx b/s
Rx b/s
Up Time
WAN
WANoE
11417
24078
LAN
Up
14455
12017
124
WLAN (2.4 GHz)
Up
1020
20
WLAN (5 GHz)
Up
8653
4351
Broadband Link
Downstream
Upstream
Connection Speed
159900 kbps
30000 kbps
This message was authored by: mae-3
Re: Connection keeps dropping
@PaulineV1977
Those aren't the full router stats but from what I can tell it looks like FTTP or G.fast with a modem. If it is FTTP then the router may be rebooting by itself which would be a faulty router that needs replacing. To obtain a new router contact Sky by phone on 150 from the house phone. If the phone isn't working because it VoIP and the connection then a superuser will need to escalate the post because of a likely faulty router to Sky.
Avatar for PaulineV1977
Hi - Thanks for the response. We have FTTP and the router is rebooting every 5 or so minutes so much so that its become unusable. We now have an engineer booked for the 4th of June.
@PaulineV1977
Your wifi bands dropped almost at the same time between 38 and 46 seconds prior to posting.  This may indicate a faulty router or a very powerful electro magentic source
