Discussion topic: Connection issues
This message was authored by: Jagna
Connection issues
I have recently got sky wifi in the 14th August, the connection keeps disconnecting and connecting again on my phone, how do I solve this?
Re: Connection issues
@Jagna if the hub lights are not changing then it is most lijely poor WiFi coverage. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
Avatar for Jagna
It is a small 1 bed room flat. New build.
