Discussion topic: Connection issues
This message was authored by: Butler007
Connection issues
I keep losing telephone and WiFi broadband band connection but sky say its OK why does this keep happening
Re: Connection issues
@Butler007  When you are checking are you using the service checker or using the broadband test to check your connection when it is having the issue.
