Discussion topic: Connection issues
This message was authored by: steve326
Message posted on 16 Mar 2024 10:04 PM
Connection issues
My sky puck and PlayStation wont connect to the internet
This message was authored by: Chlo97
Message posted on 16 Mar 2024 11:16 PM
Re: Connection issues
I'm having the same issue but when you run service checker on sky app it says everything's ok but nothing will connect and only 3 green lights on the box and a yellow. Happens all the time, sky's getting worse thinking of moving supplier. Restart the router and hope it works for you
Message posted on 16 Mar 2024 11:36 PM
Thank you. I've just joined them. Turns out all I needed to do was pull out and re plug in the internet cable. The only one I hadn't tried.
