Discussion topic: Connection issues to 2.4Ghrz items
This message was authored by: Flane
Since getting connected to full Fibre a number of non sky connections won’t connect. Solar battery still works but will not download performance stats to the solar app as it did before. Connecting smart plugs no longer works blurb on plug info suggest it is a 2.4 GHrz problem
Re: Connection issues to 2.4Ghrz items
Hi @Flane
You will likely need to do one or both of these things;
- Change your security mode to WPA2 rather than WPA3
- Temporarily disable the 5ghz band
I am NOT a Sky Employee
