Discussion topic: Connection issues on laptop & certain sites
Message posted on 11 Apr 2026 09:02 AM
Message posted on 11 Apr 2026 10:04 AM - last edited: 11 Apr 2026 10:05 AM
Re: Connection issues on laptop & certain sites
@MRSC24 wrote:
When I work from home, my laptop will not connect, it states secured no connection. However I can hot-spot from my phone, which is connected to the Internet. This is also the same for my kids laptops and we have disabled son using an eye gaze. I can't seem to use my banking app or the hive either, just will not load- if I use my mobile data it works though. All shields are off, no parental controls set, followed resetting router etc- called sky and worked for a day after. Anyone have any clues?
Have you tried using an ethernet cable between either laptop and the router? If neither has an ethernet port then you can get cheap USB to ethernet adaptors on Amazon from about £8. If it then works then this would indicate a WiFi issue.
Do your other devices connect to WiFi OK? Phones, tablets, TVs etc.
Edit: https://www.amazon.co.uk/AmazonBasics-1000-Gigabit-Ethernet-Adapter/dp/B00M77HMU0?th=1 You'd need an ethernet cable as well.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
