Discussion topic: Connection issue
Message posted on 28 May 2026 09:33 PM
Connection issue
For around a month now my WiFi just cut connection randomly all throughout the day sometimes will work for a few hours then won't work for a few or will work for 10 off work for 10. Every since I've been with sky I haven't ever had any connection in our bedroom it doesn't show. We are a flat
Message posted on 28 May 2026 10:35 PM
Re: Connection issue
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
A poor signal in certain rooms like your bedroom is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
