Discussion topic: Connection issue
Message posted on 14 Sep 2025 05:54 PM
Connection issue
Message posted on 14 Sep 2025 06:11 PM
Re: Connection issue
@Tina-R
This is a customer led discussion forum where Sky customers are here to try to help other customers. You aren’t speaking to Sky Customer Services here.
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
