Discussion topic: Connection issue again
Message posted on 08 Nov 2025 07:15 PM
Once again issue with WiFi yet again. No idea what my money is paying for with second eate service.
Message posted on 08 Nov 2025 07:43 PM
Re: Connection issue again
@Escrabb
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
