Discussion topic: Connection is glitchy
This message was authored by: amanda180
Hello. When im watching tv it glitches which then makes what I'm watching not be in time with the talking. This happens all the time
Re: Connection is glitchy
@amanda180 Is you TV device wired or wireless wifi connected to the sky Hub?
Avatar for amanda180
Wireless the sky box is upstairs connected throught the phone line and tv is down stairs
@amanda180 Ok think i have but let's confirm, it's a smart TV wireless wifi connected to the sky Hub and the Hub is connected to the OR Openreach phone line for you Broadband speed.....
Two way's to test this, 1st is just switch off the TV for a couple minutes, NO POWER to it so off at the mains, when it comes back on and connects how does it operate then when watching picture and voice in sync with each other?
You have to try to rule out is it a TV issue or a Wireless wifi Hub issue!
Ye I did this and it seems fine at the moment
@amanda180 All you can do is keep an eye on it, very hard to work out which way to go, TV or the wireless wifi hub signal! If they had been close together would have recommended trying an Ethernet cable direct, but when apart get's more difficult, but there are a few options for doing so, attack that one later if needed!👍
