7
This discussion topic has been answered Discussion topic: Connection is down
This message was authored by: AP12
Connection is down
I have run the service checker in the app and it says everything is fine Hub is connected, however this is not right because I turned it off. Connection again but within a minute it was off again
Re: Connection is down
@AP12
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
This message was authored by: Sarkysteve
I’m having the same issues
@AP12
This message was authored by: Phil272
Connection down around the same time - flashing green on the Hub but not connecting.
@Sarkysteve @Phil272
Same advice applies.
Avatar for AP12
The links given are the same as the app and give exactly the same answer
@AP12
Have you left it over an hour as suggested above?
Avatar for AP12
Yes. Understand that other users are also having problems
