Discussion topic: Connection failure
Message posted on 22 Apr 2025 05:25 PM
Connection failure
Hello, the broadband connection at home has issue recently. I have to manually restart the router and hub every 2 days due to no signal & connection failure. It created a huge problem, as i rely on the internet connection to monitor & manage my home appliances & security system.
The issue is unknown as the connection will fail anytime, the frequency is about every 48 hours, it work after manually restart, however it will fail again after 24 - 48 hours. Please kindly help to resolve the problem, thanks.
Message posted on 22 Apr 2025 06:07 PM
Re: Connection failure
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
