2
This discussion topic has been answered Discussion topic: Connection drops
This message was authored by: Saleemkk
Connection drops
Over the past few weeks, my WiFi signal has continued to drop at random intervals. Sometimes it will be fine and sometimes I'll have multiple occasions in one day when the wifi drops and nothing works. I follow what the prompt tells me to and reconnect the cables and check connection but it has not solved the issue. The website (once connection is restored) tells me there is no issues with anything. No idea and I need urgent help or I will be switching to virgin media or something next month
Re: Connection drops
@Saleemkk
It's pointless threatening to change provider on here. You are only telling other customers.
@Saleemkk
Avatar for Saleemkk
Dear Dan,
thank you for your swift response.
I am aware that I am speaking to other customers and only wanted to express my frustration towards the service provider.
as I am a competent individual I checked the websites looking for outages as well, there were none. I have also now contacted sky and i am hoping they send me a new router as I believe it is the device itself that's faulty. If this doesn't work, then I will definitely switch as for the price I'm paying it's definitely not worth the hassle.
many thanks for your contributions
yours sincerely
Sal
