Discussion topic: Connection dropped
This message was authored by: Sourit
Connection dropped
Internet not working. WiFi connected.
Re: Connection dropped
@Sourit
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
