Discussion topic: Connection dropped since around 7pm
This message was authored by: MzaKing
Since around 7pm I have not been able to connect. Yellow Internet light flashing occasionally. WiFi and power both solid green. The broadband test on the sky app says everything's fine. Reset router several times no luck.
Re: Connection dropped since around 7pm
@MzaKing  Are you in the Manchester area?
Avatar for MzaKing
No. The birmingham area.
@MzaKing  Seems it is bigger than just hitting the Manchester area.
