Discussion topic: Connecting
This message was authored by John5891 This message was authored by: John5891
Connecting
Hi
just had a new broadband router
all lights are green but nothing is connecting to the internet
This message was authored by mae-3 This message was authored by: mae-3
Re: Connecting
@John5891
Which router do you have and have you confirmed connectivity via the router stats, if it is a Sky Max router that is AI-driven then confirm with Sky it is registered correctly by phoning Sky directly on 150 from your home phone.
Zen internet on FTTP (900Mbps down, 100Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS. Dr Mae-03 PhD.
