Discussion topic: Connecting printer and ring light
This message was authored by: Janice1911
Tried to connect wireless printer and ring light but no joy, tried the trouble shooting etc
Re: Connecting printer and ring light
@Janice1911
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
