Discussion topic: Connecting HP printer to sky router
This message was authored by: Kev176
I'm having trouble connecting my HP Photosmart 5520 printer to my sky broadband router. The printer troubleshooting report says that I need to ensure that the MAC address filtering is enabled but I've no idea how to do this and I can't seem to be able to address printer as a new device withi the MySky app.
Re: Connecting HP printer to sky router
@Kev176
Sky Hubs don't do MAC filtering.
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Avatar for Kev176
Thanks for your response. Unfortunately I'm not really technologically minded so would you mind explaining how I do that.
@Kev176
https://www.sky.com/help/articles/access-your-sky-broadband-hub-settings-max-hub
