Discussion topic: Conection to my phon
This message was authored by: Constantinstan
Conetition coming and going  we have this problem for on week, im not happy at all
Re: Conection to my phon
@Constantinstan Landline or mobile?
Landline help is linked below for you!
Fix problems with your phone | Sky Help | Sky.com | Sky Help | Sky.com
Avatar for Constantinstan
My broadband is coming and going  for at least one work
The Internet connection fron router to my phone is the problem
@Constantinstan Is it one or the other or both the problem's you have!
The landline phone link was sent above for you earlier in the post!
I don't have landline phone deal
I Have broadband only
@Constantinstan So you are aware, there is not ONE Single sky system out there that is broadband only, so you DO have a landline.
Anyway just call sky and have them take a look at what is going on with your connection, that is done by dialing 150 from your landline phone connected or not!
If you wish to check and test yourself then below linked also!
Try running the line test here to see if any faults are found:
