Discussion topic: Computer said no
This message was authored by: DickThompson
Message posted on 13 May 2025 05:22 PM
Computer said no
Had fibre optic fitted on the 7th may all my pads Mobile phones work but my computer said the network is not connected Have deleted network rebooted still the same Error code is 651 done every thing sill the same Anyone else had samething
Find out more
Message posted on 13 May 2025 06:06 PM
Re: Computer said no
Are you entering the Wi-Fi password correctly as it is quite easy when entering a password to get a 0 and O and a 1 and l the wrong way round so are you sure you are not doing this as it needs to be entered as it is printed on the hub itself.
Find out more
Message posted on 13 May 2025 09:17 PM
@DickThompson Was the router also changed when you got fibre or is this the same router that you had before?
