Discussion topic: Community Hub is lying again
Message posted on 07 Mar 2025 06:01 PM
You can test everything u wish on the app and it tells u everything is fine, which is a shame as I am sat in front of a blank screen and plenty of people have logged on detect ur sky. Is this ur way around not paying ur loyal customers compensation for a shocking services
Message posted on 07 Mar 2025 06:03 PM
Re: Community Hub is lying again
@MAMax
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services. Sky won't respond to you on here.
