Discussion topic: Coaxial cable
This message was authored by: Megchambe
Coaxial cable
 My white cable, which I believe is the coaxial cable has torn and the wires inside are exposed. I no longer have internet connection
Re: Coaxial cable
@Megchambe  Sky Broadband does not use coaxial cable as that is normally used for aerial or satallite dish connections.
Perhaps you could post a photo of the cable in question?  This will enable the community to help
