Discussion topic: City fibre
This message was authored by Derek1810 This message was authored by: Derek1810
City fibre
Is city fibre something sky broadband can use to increase our speed and connection to wi if?
Re: City fibre
@Derek1810  No, sky only use the Openreach network.
Re: City fibre
@Derek1810
No, sky use openreach infrastructure
Could you post your hub stats to see what speed you are getting
And enter your full postal address below and post the table after removing your address from the image to see what is available
Re: City fibre
@Derek1810
CityFibre are an altnet company laying full fibre infrastructure which is effectively in competition with the BT Wholesale/Openreach national distribution.  I believe TalkTalk, Vodafone and Zen currently have distribution over CityFibre as well as Openreach, but so far neither Sky or BT has chosen to do so.
This message was authored by Mr+Slant This message was authored by: Mr+Slant
Re: City fibre
Sky trialled a FTTP service using CityFibre infrastructure in York back around 2014 (branded as UFO - ultra fibre optic) and pulled out of the trial a couple of years later. I think its safe to assume Sky won't be using CityFibre infrastructure in the next few years.
This message was authored by Mini+Mo This message was authored by: Mini+Mo
Re: City fibre
I do wish Sky would join  up with City Fibre, as they are starting to lay fibre here,whereas BT Wholesale/Openreach have said we are not in their current fibre rollout plan for a more few years.
Re: City fibre
@Mini+Mo
I'd suggest there's naturally some reluctance on the part of ISPs of the scale of Sky and BT to use such backhaul, because the altnet providers are typically still in a venture capital startup stage and don't yet have viable long term finances.  It's quite likely that not all of them will survive, and that would be a real problem for customer provision: unlike the failure of the rival electricity providers there's no regulated system to keep broadband going when an ISP or network provider goes bust.
UK ‘altnets’ risk digging themselves into a hole
Re: City fibre
@TimmyBGoodI think City Fibre is a safer bet, than a lot of the smaller altnet providers who I predict some will go into administration or bought out by the bigger altnet providers in 2023..
