Discussion topic: City Fibre
Message posted on 09 Feb 2026 10:34 PM
City Fibre
I have an email confirming they were due to come last week. My husband stayed at home and no one turned up and no communication received. I don't appear to have any way to contact them to complain and the system won't let me reschedule the appointment.
Message posted on 09 Feb 2026 10:38 PM - last edited: 09 Feb 2026 10:41 PM
Re: City Fibre
@CatMummy You deal with your ISP, that is sky no one else!
Sky Broadband & Talk installs | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 10 Feb 2026 05:09 AM
Re: City Fibre
@CatMummy
These are the current methods for contacting Sky, and depending on the issue some will be more appropriate than others …
🟢 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟢online help via this link
https://www.sky.com/help
🟢Sky Assistant 💬 should also be available via
🟢Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟡Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed at a weekend.
