Discussion topic: Chsnge router
Message posted on 23 Jan 2026 01:47 PM
Chsnge router
Message posted on 23 Jan 2026 02:10 PM
Re: Chsnge router
@MM80 Do you have the new Gigafast, which one are you going for, if you have the sky Broadband Hub it may not be for some packages!
Message posted on 23 Jan 2026 04:14 PM - last edited: 23 Jan 2026 04:15 PM
Re: Chsnge router
Sky is swapping Q Hubs for Sky Broadband Hubs.
The Max Hub goes to customers who opt to add the WiFi Max subscription supplement.
Gigafast+ Hubs are currently only offered on CityFibre circuits, to support the 2.5Gbs and 5Gbs which aren't possible through a Max Hub.
