Discussion topic: Change wifi ip address
This message was authored by Karenh012 This message was authored by: Karenh012
Hi
Wont let me change wifi and broardband ip address.
Needs to be changed to run with home network. And fixed ip router address etc.
Any help?
Or wont it let me change it?
If so it wont be much good to us i dont think
Karenh012
Re: Change wifi ip address
Do sky answer. Or do they leave it for other people to answer?
@Karenh012
Sky support don't post here: it's a customer to customer forum.
You'll need to log into the Hub admin settings, which is best done from the web browser on a wired device, and typically doesn't work using Safari from an iThing over WiFi.
IP address is 192.168.0.1, username is admin, password is either sky or the WiFi password from the label on the rear.
@Karenh012
https://www.sky.com/help/articles/find-and-change-your-wireless-password
