Discussion topic: Category of Ethernet cable extension
This message was authored by chrisnsol This message was authored by: chrisnsol
I need a longer Ethernet cable but so many to choose from. Just had fibre installed and want to move router
Re: Category of Ethernet cable extension
@chrisnsol  Cat 5 or above will do, make nsure it's fully wired for gigabit speeds
@chrisnsol
As @GD1 indicates, Cat5e is fine, and preferably pure copper rather than CCA (copper-clad aluminium) : the price difference is negligible for shorter lengths.   RJ45 (ethernet) plugs at both ends.
(Actually, CCA shouldn't be rated as Cat5e at all, but some resellers are less than scrupulous)
